RedlineFeline
Standard Bore
Hello
I would like to remove the front fender on my 2025 Rocket 3 Storm GT; show off that fat tire more
Looks like a few bolts hold it on. Not sure if there is much more. But I don't know about these things. Any reason that I should just leave it alone? (I never ride in the rain, always on roads, doubt I will suffer from anything significant that would be blocked by a fender).
Thanks!
[UPDATE] Well, I went ahead and just did it. The fender is plastic. There are 3 bolts on each side which pulls it off the bike and then there are 2 bolts on each side which require removal (all are 5 mm hex bolts) to get the sides off the fender so you can pull it out of the fork. It wasn't connected to anything else so it looks safe. I put the bolts back on the frame, not sure if that looks any better than having them off. Otherwise, I like having both fat tires showing now ! (because I also did a tail tidy in the back).
Thanks!
