Installed TORS today
Thanks @dougl you're right, it wouldn't be suitable. I thought it was something refined from the stock tune for TORS and cat deleted.
You don't have the Triumph tool, and if you load a tune where the O2 sensor is disabled, it's not going to adapt anyway.
The ecu definitely adapts over time. I used to run the decel tune but with the O2 on. Initialy, after reseting adaptation to the factory settings, the popping would be much diminished. But the ecu tends to lean it out in response to the o2 signal and after a while the popping would come back.
I sorry mate but all these facts and figures does my head in, All I did with my 2011 R3T was buy a set of TORS and a K&N under seat (in standard air box) and a GoPro GPI fit them then then take it to the Dyno guy who derestricted it to his own custom tune and set it up for my style(old Fart) riding that was 12months and 10,000 Ks ago it goes like a scalded cat and runs as smooth as silk no popping or rough idle /or stalling more than happy with my only slightly modified Rocket
Sometimes I wish I was more savy to the the intricate art of electronic engine tuning ,but at times I am glad to follow my Dear old Dads advice Don't Feck around with things you know nothing about,I just bolted on the TORS and slipped in a K&N filter in the original air box ,gently rode it up to the Dyno bloke ,he installed his custom Tune? and dynode the bike 12 months later it is still running nicely no
Yep I agree, my last resort was take it to the dyno guy ( any recommendations for one in Brisbane?).
So I have decided to get the bike dyno tuned and she is booked for June 1 (@cusso ken ). They use TuneECU so it will be interesting to see how the map turns out. I will grab a screenshot of the 20050 comparison when it's done for those interested in seeing the differences in the map.
Good one! I can only comment on my own experiences ,but I have had great results with several of my bikes with the Dyno guy near Newcastle NSW,
That's great you have a tuner who can work with TuneEcu.
I think I have this thing running reasonably well at last (shouldn't speak too soon!). So after a bit of mucking around with TuneECU, learning the routine for uploading maps and resetting adaption I think the bike is running as well as I think is possible without further refining it on a dyno. Here is the basic situation and what seems to have worked:
Bike: 2006 Classic, TORS and cat delete, K&N under seat filter, 95 Octane fuel (Aussie, BP), 20226 map.
Issue: High/Low idle, some backfiring on decel. Running the bike hard through 2,3,4 (~6000 rpm) would stick idle at 2000 rpm and not return to idle until off/on cycle. Low throttle around town in traffic and high temps the bike would not idle and die.
Things I did: Sprayed WD40 in and around the ISC, I read through a lot of old posts about the issue and saw this mentioned. I figure it was getting stuck because (I am just supposing, I am not an expert), as it got hotter it just got worse (heat=friction). Throttle position 0% stepper stuck. Higher throttle positions near WOT and throttle close, stepper can't go back. Shut down and left it overnight. Next day bike started, but wasn't easy to start. Rode about 150Km highway, the bike ran pretty good but was a bit difficult to start on 2 stops along the way. Pulling in it wouldn't hold idle and died. I figured the WD40 had helped but had evaporated (it is not a lubricant as such). I went back in (around the stepper motor and various bits attached) with INNOX and let it soak in a while.
After trying the 20050 map I put the stock 20226 (Triumph TORS config) map back in (bike temp was near 100C, to reduce wait time for adaption). This time a ran a few tests (idle voltage test was .058 - .072(ish). After moving all the bits (in software tests) the bike started well! did the Reset Adaption while bike was running. and let it sit a while 8-10 mins. I shut down and waited a minute then restarted. It started normally and I went for a 30 minute highway ride to do a bit of load adaption. The bike seemed to be "normal" again!! I have left it overnight and not started it today. Tonight I will see how it is all holding up and report back.
Anyways, I think I will cancel the dyno booking and stay with the 20226 tune for now. If it ain't broke don't fix it (!) for now anyway and ride a bit more. I think I will still like to do a dyno tune, but when everything is sorted out properly.
