Injectors, clean or replace
Kevin Frazier had several good posts on cleaning and testing of injectors, and the company who did his work. I used same co. later, and think it was around $90.00. I didn't like their o-rings though, and purchased set from Triumph dealer here.
I should have kept my o rings before sending off injectors, rookie mistake. Thanks for pointing it out but I am glad I saw your post. What is it that you didn’t like w rc o rings? That I should look for. Update o rings work well from rc injector no problem
Seem like were bigger, thicker, wanted to roll out of bore when installing. Original were red and black. I will look up numbers in the morning. I used lube when installing in throttle bodies.
lower o-ring-T1245006 upper- T1245016
Thanks looks like I too will be making a call to the dealer tomorrow.
So I like so many others opt'ed for factory o-rings, I got all giddy and swaped them out last night, I'm sad to report I have the same but slightly lessend problem and the bike just runs like crap until 3500 rpmspiting missing backfiring. it has a custom map that was done by the first owner when he had the cat back done, I was thinking go back to the factory map
  • Like
Reactions: 1K9
What are you mods? Intake/Exhaust?
I have an '05 and was having idling issues, rough running and hesitation/lag at higher speeds.
It was a combination of all these things to get it back to 98% perfect.
1. Front two plugs were fouled - Cyl #1 was running too rich. Cleaned. (old plugs had fouled last October so it was going downhill since after RAA-West)
2. Cleaned and oiled entire throttle control area and cable. Gunked up bad. Helped but didn't fix.
3. Bad gas in Florida. Ran lots of STP water treatment and Seafoam through it but ended up draining tank and putting in a new fuel filter. Helped a lot as old filter had 60K on it (oops, don't wait that long).
4. Checked Primary TPS (OK) but found Front TB was off. Rebalanced it and it helped. Needs to be done again after all the other work.
5. Battery - couldn't keep bolts tight. New battery helped.
6. Installed a different map: Power-Tripp-Jardine 3xK&NRU-2780a, reset adaptations, 12-minute tune. Helped a little.
7. Discovered that the crankcase filter was horribly clogged. Cleaned it and will check and replace it when I get home.
-- I'm hoping it was due to the poor running condition and not a more serious internal issue.
8. Kickstand delete wire splice went bad. Redid splice, ordered used sensor connector and installed. Seemed to help. Check for electrical shorts, our ECU is finicky!!
9. Crimped and added dielectric grease to all 6 coil connectors again.
10. My bike runs best on Sunoco 91 Octane but it's hard to find 91 here in FL. 93 makes it idle high and 89 seems to run weak so I've been trying to add fuel every 100 miles and alternate top-offs with 89 & 93 if 91 isn't available. May not matter as much after all the fixes.
11. Main MAP hose was loose and even came off causing bad hesitation at speeds over 65. Replaced all 4 hoses plus connector. Zip tied the ones on the connector.
THAT last step did it - it is Much smoother at idle and has zero hesitation at all speeds now and runs strong. Almost like new!
I removed my stepper motor years ago and set idle manually but others will need to consider checking ISCV.
I removed the butterflies a long time ago but others will need to check Secondary TPS voltage along with Primary and ISCV.
I also ordered additional positive & negative terminal cables to double up and a used coil with two plug wires but didn't install them yet. Swap coils around if you suspect one is bad.
I'll keep the entire list for others but you can ignore the ones you've addressed already.
Check the low tension leads to coil make sure they are tight as they can loosen over time. No 1. Oil pack is right behind the steering head PIA to get to - squash the blade terminals with flat pliers (not too much tho) and reinstall the wire do this for all 6 coil trigger wires
Do you have a picture of where they are?
