Idea's for a tool kit
Frosty Rider
Turbocharged
Toronto, Ontario, Canada
2010 R III T, 2020 R 3GT, 2001 HD CVO WideGlide
When i bought my R3T it didn't have the tool kit, i have started putting one together, i seen the one it comes with, and it seems pretty useless, given that most of you have had one longer then i have i'm wondering what you find useful in the kit.
Currently i have a set of Allen keys, screwdriver with various bit, wrenches from about 9mm-17mm and 1/4 drive with 2-inch extension and sockets from **** small to 12mm
just wondering if there is anything you think i might be missing?
Captain, this site is a wealth of information obtained over the years.
Best to use the search function, and then ask your questions. It's more efficient for you, and for the rest of us.
You might look at this thread, and if there is a gap from your perspective, just reply to that one.
Why, oh why...
Thanks for the link, I had tried a search, but i think my computer was giving me a hard time with it and it showed nothing, a little unexpected since i have found an answer to almost every other question i could dream up in here
Joe, I would also like to look at that post but the link is not engaging. :thumbsdown:
Thanks for the fix
Main items in mine
* Plug Kit and compressor
*Zip Ties
*100MPH tape
*Leatherman Multitool ( stealth black carried it in the Ghan )
most importantly good Roadside Assist membership
I Forgot to add one very important item, a small LED torch and spare batteries , plus a way to keep you phone charged.
It's always a delema as far as what to carry on your bike. Let's face it, you are not going to do a major repair along side the road so I focus on the most likely things I can fix. You have a good start. Here is my list and your going to think I'm crazy. A few of the smaller wrench sizes 8, 10, 12, 15 and sockets, a small 1/4" drive handle and a 1/4" socket to put some of the short hex bits and torx bits in, a 1/4" drive screwdriver type handle, a 1/4" to 3/8" adapter, a simple screwdriver with various bits, a spark plug socket, a small channel lock and vise grip, definitely a small compact multimeter, an ODB Bluetooth connector so I can use it with TunECU on my phone to check a code, a couple of spare relays (1 regular and 1 starter relay), a Panasonic eastern beaver type relay, a good compact led flashlight, I keep circuit diagrams on my phone as well as a PDF copy of the manual posted here, spare fuses, a couple short lengths of wire, several scotch locks, about 3 ft of electrical tape wound on a small stick, tools to plug and fix a tire, CO2 cylinders to air it up, a tire gage, a switch and fused jumpers to bypass the ignition should it go bad, a universal throttle cable that I might be able to rig up if needed as well as a few other things that I can't remember right off hand.
Now you may think...how does he have room for anything else? I have condensed all of this stuff down to a two or three small waterproof plastic Plano containers in the bottom of my bags. If you organize it right, it really is pretty compact.
My focus is repairing a tire, fixing a cable, jumping a bad clutch or kickstand switch, replacing a bad relay, bypassing my ignition switch, replacing a blown fuse, tightening or adjusting something, trouble shooting a code, and tracing an electrical problem. There just isn't much more you can do on the road.
Oh....and most important, is a cell phone charging cable and the best Good Sam Motorcycle road service coverage I can buy. Good for up to a 100 mile to a repair shop or home.
