cskals
.060 Over
Hi fellow Rocketeers.
My 05' won't start.
I have had it split apart, except the engine, and when I put it together again, it won't start.
At first, no issue, it started fine, once or twice.
After that it got harder and harder, and now it won't start at all.
I think it has been started 5 times overall, but it got harder every time.
I have found out that it does not spark, I believe everything else if fine.
1. Fuel pump works and build pressure.
2. Plenty of battery.
3. Just put new relays on.
4. Installed new wires from battery, 35mm2.
5. New sparkplugs.
6. Fall sensor ok.
7. Gear position sensor ok.
8. Crank position sensor cleaned, but not sure how to check if it works?
9. Turns fine in the starter, but I have ordered a Toyota upgrade.
When pulling a spark plug to check for spark, it does not spark.
I have measured the following:
Battery: 13.0 V
Battery when pushing start: 10.5 V
Relay: 12.7 V
Coil: 12.7 V
Coil between pins with ignition on: 11.4 V
Coil between pins when pushing start: 8.2 V
The low voltage on the pins concern me, 8.2 V is not a lot, but how much does it require to fire the plugs?
What am I missing?
Thanks in advance.
My 05' won't start.
5. New sparkplugs.
6. Fall sensor ok.
Battery: 13.0 V
Relay: 12.7 V
Coil: 12.7 V
What am I missing?
Thanks in advance.
