How to flash map using TuneEcu?
Grizli784
Standard Bore
Triumph Rocket 3R
Hi, I have Triumph Rocket 3R (vin:SMTYBG11J5NAX53...., europe version) and want to flash unrestricted map for the bike just to open electronic throttle valve in sport mode to 100%. I have read a lot of information in the internet including this forum and I did not find step by step instruction how to do it. Maybe I missed something and You can send me a link or describe main moments? I have already bought TuneEcu and connected via bluetooth to my bike's ECU, I know how to open and make changes in ETV tables. As I understand, for now the best free available map for my bike is Pener's modified map- Unrestricted-31254Map-Tune-ECU for all countries. The main problem is how to flash map, because when I connected to my bike, when engine runs, TuneEcu works ok, but when I turn off the engine, after about one minute TuneEcu loses signal with bike and asks to switch on the ignition, so I dont understand in which position should be ignition bottom, when only display switches on or in second and last position when fuel pump switches on? Should I pull out headlight's fuse before flashing Ecu or not? Should I conect battery charger during flashing Ecu? Help(describe or send a link) if You can... Thanks!
