Kind of a crappy video
It was my first with a new gopro
camera , just checking sound and
how a wide angle lens look like
Should get a little better with some practice
Using a wide angle lens changes perspectives
objects look far away
ex: tailing car @ end of clip looks like 150 - 200 ft
away @ closest point / was actually maybe 30- 35 ft
ex: curves looked like huge sweepers , that you could take
@ 100 + easily / 25 mph posted curve 50 mph pressing it
a bit on a cruiser YouTube - Triumph Rocket III
WOW thats too cool!!!! Ive never seen a video so stable!! How did you mount that on the tank!!!! That exhaust sounds sweet and it appears like you tuned it quite well!!
Jlm205 ,
I put 1 1/2" exhaust pipe extensions over
the cat bypass pipe inserted 4 " baffles in 2 of the short extensions of the bypass pipes .
Welded up end of 3 extension of the 3rd bypass pipe , then drilled seven
3/8" holes in end plate .
Then slipped on the chrome tips over the extensions
These $1284.00
Shorty Exhaust for the New Triumph Rocket III
IMO mine look cleaner , sound a bit better
flow very good ( gained 3.2 hp ) & last but not least mine cost
$ 102.00 ... yes I know a true header would produce more
hp
