Help Please with my 2007 Rocket anyone???
The tuneecu works great on lap top with the cable conection and is my preferred way but it needs android to work.
A $100 android laptop and the correct cable and you r ready to go.
I have a Lenovo lab top, will that be good?, have No Idea what cable to buy...
It works with Android and also Windows but they look different from each other on the screen, navigation thru them is different but whatever system you use will work fine after you figure out how to navigate it, which isn't hard - I'm the dumbest mofo in the world when it comes to computers & I figured out how to use the Android version even tho i've never had an Android phone
Lonelec
it is the dongle cable combined.
it has component/dongle that plugs into your obdII connection that is located under seat beside your battery.
the other end of cable plugs into laptop.
mine came with two adaptors that will plug into phone.
hth
The Lenovo Google won't work, not compatible. Learned this after I purchased it. Samsung Galaxy Tablet 7 works great, probably later model work as good.
Thanks for the Call, here is what I pulled up on Amazon. Let Me know and Thank You Dean. https://www.amazon.com/Scanner-FORScan-Adapter-ELMconfig-Diagnosis/dp/B083FML519
