GREAT New Tire Report
I believe that it is the tread pattern that makes a tire "directional" not the way it is constructed. Most automotive tires spin either way. I would run it in the proper direction myself. Just my 2 cents
Patrick,
When I ride in the wet, I actually remain much more conservative than when on the dry.
I ran the Azaro backwards for over 12K miles and had absolutely no issues riding in the wet.
is there another PATRICK? out there cause I did not ask
Why are you running them backwards?
My apologies @1olbull, I stand by statement in regards to the construction not having any bearing in the direction that a tire rotates but just realized that the tread pattern on the front tire of a M/C is backwards to the rear. I look forward to replacing my front tire with the Michelin Road 5 and will be installing it backwards as you have stated!
Not sure about modern radial tires but in the old bias ply tires were constructed different front to back. It was supposed to do with the way the stress was applied. Rear tires rotated forward for acceleration forces, front tires rotated opposite for breaking force. Many had some tread pattern front to rear just directional arrow.
