Mate might have to pester you in the near future to drop over yours and check the rear drive lube again , im still not keen to pull the rear drive apart myself
Geez, That's a bugger.
Should be covered under warranty - Unless they find a reason not to.....
It is odd how it just started to leak - looks like the gasket has moved.
Part # T1260079 cam cover seal $27.25 + Shipping from NCY
Email Andy andy@ncyyamaha.com
Team Moto Springwood hooked me up , got plugs, gasket and bolt gasket/washers couried out for $200 , bust out the tools on Sat I'll be buying a good tension wrench as well so anyone got any tips for checking steering bearing tension ?
that must be a common problem as I blew three gaskets in 18months and in the end triumph put a new valve cover on as well as a new gasket.Tech put a straight edge on the front left side and it was warped.Get it thoroughly checked out before re-assembling it
