gear selector problem
askit
Standard Bore
scotland uk
Is the gear selector bolt coming loose on the end of the selector shaft a common fault in the rocket, my bike has done 2,000 miles and it appears that the linkage does not connect to anything in the box, if you have had or have the same problem please let me know as i want to make a warranty claim, my bike was lightly damaged cat d, and i dont know if triumph will accept a warranty claim, but if it can be proved that this is common fault then i will seek legal help. :cry: THANKS
I would not be describe this as a common fault, but it has occurred before.I suggest you approach your dealer.Hope you get it sorted.
Not had that problem, the nearest was the gear selector rods from the gear shift coming loose and falling apart after 2000 miles, but it was just a case of bolting them back on with some loctite.
This same thing just happened to my bike while out on a ride with some of the Sydney boys.It is stuck in fifth gear.
Mine is WARRANTY
hi
my bikes still at the dealers waiting to be looked at (1week so far)
had noises from gear box sounded like it was half in gear and half out
i will let you know what the problem was when the shop gets around to looking
micromike
