Guys here is a news flash. Triumph does not lube the headstock bearings. If you look at the section in the manual about swing arm bearings and buy a new set they clearly state Lupe the bearings. The same factory rust prevent will be on your headstock as well as your swing arm bearings. This is not a grease lube. Just a factory preventive rust coating. Why Triumph does this I have no clue. They should be shot or better yet let the executives of Triumph ride out a wobble at 100 plus. Screw the tire ordeal. Take it apart and apply some real lube. Means packing the bearings. Did this after only 10,000 miles and never looked back. Now at 69,000 miles on a 2015 Rocket X ready to replace all. Well already did.
