ZoneIII
My new R3T is my first motorcycle with tubeless tires so I want to be prepared to fix flats in the middle of nowhere. I've already ordered a good 12V air pump and sticky string patch kit. However, I've fixed enough flats with tubeless tires on other machines to know that if the tire is completely flat and the bead isn't sealed on the rim, no small compressor will push enough air to seal the bead. (Even my big shop compressor usually won't.) So how do you folks handle that problem? I've used ratcheting straps to compress tires to seal the bead on the rim and I've even seen a neat trick where a shot of starter fluid is shot into the tire and then lit and the sudden pressure seals the bead (but I haven't tried that). Perhaps a CO2 Capsule and adapter would do the trick?
Anyway, have any of you had to deal with that in the middle of nowhere and, if so, how did you handle it. I want to be completely prepared for that situation when on the road.
