exhaust and other parts interchangeability
Toddyboy
.040 Over
Ontario Canada
2011 Rocket 3 Roadster
Hi there brand new to the whole Triumph Rocket 3 world as I just purchased my 2011 rocket 3 Roadster and was curious on exhaust interchangeability as I see plenty of touring performance exhaust much cheaper than the carpenter racing zard and Jardine any help on this subject would be greatly appreciated as I would love to squeeze a little more sound and possibly a little more power out of this beast
Ok first you have a Roadster so none of the OEM exhaust from older non Roadster Rockets will work do to your ABS system. Also the Touring pipes hang from the hard bag frame mounts which you do not have so without modification no touring pipes will fit. Except for the lousy power robbing tractor header. You will be lucky to purchase a Jardine system for the Roadster and if so it will be used. The older Jardine pipes will not work because of the ABS box behind the engine on the right.
You already know the after market headers and systems are pricey. Probably not what you want to hear. If you look around you will see a few cans that were adapted to the header but not much.
If your not wanting to spend a lot look around for a set of used TORS.
Welcome to the nut house
Thank you very much
Get the Roaster TORs and then a good dyno tune. Together they will be under $1000. If you want to you can modify the air intake with Triple K&N or a Ramair for about another $175 or less. More sound, more power and more MPG. Worth every penny.
Ok. You seem to know a lot about this. So. I have a 15 Roadster, all stock at the moment. Unfortunately, I am not a big fan of upswept pipes, which all roadsters have. I do love the look of the touring though. Mainly because they sit level with the ground.
Any suggestions on alternative's to get this look?
Yes Mr. Bryant has a clean system single or dual with his own brand on it. I've seen his header up close. You can tell he takes pride in his work!
How to I contact him?
I just noticed you're in Forest City!! I'm in Mackinaw! We need to get our Rockets together this summer!!
