Emission removal
Also noticed that the charcoal canister had HONDA molded on it. I figure, if you get rid of stuff you don't really need, that much less to crap out on you later
Bob you said four 5/32"caps are required if I remove all my hoses I will need six caps!!!!!! I plan on doing it on a 2011Roadster are you sure it was four?
@scot in exile remember three of the hose coming from the throttle bodies run to the map sensor I do not think you want to pull them unless you set your F to L switch over to zero so it does not look for input from the Map sensor. It will still need to be plugged in though to not throw a code. I would just worry about the ones that deal with the emissions crap.
One would be careful to examine hose routing and not pull the wrong ones!
Can someone help me understand this? Why are we removing the canister? Do we expect a performance increase? I haven't experienced any of the problems OP is describing on my '16 R3R. I would like to put a soundbomb in the space but am fearful of removing the part...
Making space for something you want is the only reason to remove the canister. It doesn't do anything plus or minus for performance. Well maybe minus if you don't reinstall the vacuum hoses correctly.
I removed mine to make room for the series rectifier/regulator recommended by @DEcosse .
Still thinking I'm going to purchase one of those obnoxious, chromed, dual bell horns, mounted on one of the front engine dresser bars.
wow. thanks for all the useful intel. totally tits! youre the man, bob!!! good luck everyone, and have a happy New Year!!
