Dyno'd
ducktaped
Got my bike back. Got the A/F ratio sorted out. Got 148Hp and 154 torque with 3 K&N's and Jardine. I can post the map in a couple of days if anybody is interested.
good to hear everything worked out! how was the starting run?
Hi Ducktape.....Glad you had the success the results show. I have a Roadster and If you do as well and used Tune Ecu I would be extremely grateful to have access to the tune. Thanks!
Bagger, it starter out pretty close. It was a little lean and 145hp. Most of the hesitation is gone. Still a touch noticable in 4th and 5th under 3k. Overall very nice power all the way through the gears to 140mph.
got the same set up so I am definitively interested which tune and which software also
I believe to have 20145 loaded with tuneEcu on my bike..but i am such a klutz with computer!!
Fat Franks Tune
Hi Bagman,
Here is the result of the tune I did for Fat Franks Roadster. 3 x K & N's and Jardines
155.85HP and 160.46ft-lb's
Let me know how to post file's and I will post the tuneboy file
Bruce
Dyno results
nice dyno numbers but the the results are not 100% correct. see in the top right of your results it says STD smoothing:5 well that correction is 18+ yrs old to get accurate numbers the format should be SAE smoothing:5
