if this is for the Roadster, it's pretty cut and dried. With the header on and crossver bolted in place, The pipes just slip on and bolt up to the rear passenger pegs. You shold be ablr to see when you hang the stuff. The shields should be easy enough. Good luck and I'm sure if you look, you'll find a view of it.
