A3rik
Ok, so I finally got to take my new 08 R3s out for its first ride yesterday, and notice led that it was ****ed tricky to shift into second- it felt like the clutch wasn't fully engaged and I was bouncing off the gear back into neutral, particularly at higher revs (4-5k).
I read all the posts about clutch cable adjustment and ended up following the advice about using the cable sheath to measure 2-3mm (I tried the "feel the lifter shaft" method, but I couldn't definitively tell when I was feeling it bump). At this setting, shifting into second was much easier, but it was slipping at higher revs.
Did I take out too much freeplay if I can measure 2-3 mm with the cable sheath pulled out? Or is the cable adjusted properly and my clutch is just worn out? It has barely 7k miles on it, but I don't know what the previous owners may have done.
If I need to buy a clutch, I'm seeing mention of a necessary update, but I'm unclear about what years this applies to.
