Difference between U.S & European PC III maps ?????
trackerjack
.040 Over
Salon de Provence / France
Hi,
I've just seen that there is two new PC III maps available on the Dynojet site for R III European models.
M510-001 - Completely stock bike with Dynojet O2 Sensor Controller
M510-002 - Stock exhaust with catalytic converter removed and Dynojet O2 Sensor Controller
M510-003 - Triumph performance exhaust, Stock air filter and Dynojet O2 Sensor Controller
M510-004 - Jardine full exhaust, Stock air filter and Dynojet O2 Sensor Controller
M510-501 - European Model Stock exhaust Stock air filter Dynojet O2 Controller Fitted
M510-502 - European Model Triumph Performance Slip-on Exhausts and Catalytic Converter Replacment Pipe Stock air filter Dynojet O2 controller Fitted
It seems that there is some differences about the O² sensor.
On the U.S maps "Dynojet O² sensor controller"
On the Europe maps "dynojet O² controller fitted"
Do you have some informations about that ?
Thanks...
it is the same on the FJR1300 which I own and have a PC111 for and it is lumpy as hell with the USA base map but fine on the European map odd I know but happens ;)
Now you've done it RedR3...you've gone and fed the little troll so it'll live long enough to go back under it's bridge until next time. Ignore it completely and it'll starve on the road until it gets run over by a Rocket :wink:
Write your reply...
