Hi folks
On the way home late in the dark, suddenly without warning I had no gear selector. The lever was still present but not attached to the gear box.
Check the top link - its a ball joint with a threaded shaft that screws into the gear box actuator arm from the inside. There is a foam washer over the threaded part, that expands to fill the gap so if it starts to work loose, you dont see it.
Now I know where to look, you can tell if its on the way out by looking at the hole in the gearbox actuator arm, now its tight the end of the threaded part is flush with the outer faxe of the actuator.
If you compress the foam washer, the threaded part has flats for an open ended spanner (8MM). Suggest you check its tight and stick some lock tight on it.
(If it does fail on you, I found 3rd was a good alround get you home gear)
