Carpenter 210kit
danny42
Standard Bore
rocket 3 classic
Hi guys I got rocket 3 classic with Carpenter racing 210kit and carpet street road exhaust ,.my bike still have Power Commander V , is there already finished map for same setup which i can use to flash ecu directly with tuneecu software???? Where to look for those finished tested maps?
I know there are times out there but you might also want to consider going to a dyno and having it done to fit your rocket. Even the same 2 bike setups can have slightly different maps from just altitude and some other stuff. But I'm sure you can find the tune you need. There is a library of those tunes. I'm a bit of a novice to it as well but it was easy to find once I searched around. I'm sure someone will point you in the right direction
