Brand new Rocket 3 burning oil issue
Attornery!!
There is other issues with the oil pump itself on these units. The pump stops pumping on occasion and the oil light doesn't seem to pick this phenomena up. Be wary Rocket 3 owners.
That should not be possible.
But you should check that the oil pressure light is working when you have the ignition on and not running it should be lit.
Sounds like by-pass valve in pump is sticking open and is allowing oil to bypass.
Can you reject the bike and get your money back at this point in the proceedings, or is it a bit late?
My gut feeling is reject rather than let them remedy under warranty. It's a brand new bike, a premium one at that.
One that you should expect to have an engine that runs as it's supposed to.
It's not like having a defect in the paint, or a faulty display unit that can easily be rectified.
If it was me, I would reject and start again.......if I could.
