When I decided to take my trip across the United States I wanted some type of throttle cruise control device. I wavered between the throttlemeister, the homemade throttlemeister from the existing bar end caps, and the Brakeaway. The homemade version had the advantage of cost, the throttlemeiseter runs I believe $113 and the Brakeaway costs the most at roughly 200.
I went with the Brakeaway because it appeared to me the easiest to set while riding and the easiest and fastest to disconnect. The throttle bar end type requires you to both hold the throttle in the position that you want it to be and then also turn the control. In order to turn it off you must move your hand to turn it.
The brakeaway had the advantage of either engaging or disengaging with the press of a thumb. Also it you touch the brake it disengages. The device appears to very well made out of aluminum. Sounds great, but unfortunately I had real issues with it.
It takes a fine line to get it to the point where it does not bind the throttle, but still be effective. In addition on the rocket it uses a lot of the handgrip. This is not a real issue with me but might be for those with larger hands. To get it adjusted correctly you have to cut off the rubber flange on the grip, otherwise it will not quite reach the pivot screw of the brake lever to which it attaches.
You need to attach it to the pivot bolt, and not the adjustment bolt thinking that is the pivot bolt (first mistake). I had this thing set several times and it seemed to be OK and then when I rode for a while it seemed to go out of adjustment and not engage. At one point one of the adjustment screws fell out. I was able to replace it and this time used locktite. I was 2/3 across the country before I got it to work consistently. When I got it right I liked it. It is very handy to have some way to hold the throttle in position when either stretching out your hand, or adjusting something using your major hand if you are right handed.
