brake light horn and turn signals
borntoride63
pennsylavania
Hi to all, asking for a rider in Pittsburgh, he has a 2010 Roadster and just recently the horn, brake light and turn signals quit working! any thoughts?
Asumng he has checked fuses use a multi meter and check all the connectors, also add a bit of dielectric grease to connectors, you would be amazed hoow simple some of these annoying things can be and yet ten simple fixes, if you need a manual there is a link on Tom Hambugs TuneECU site's download page
thanks Hans I will relay the info
I could be wrong but it looks like all you mention are fed by fuse #4 (15 Amp). May want to look there first. If that is good, it could be a ground/contact issue. Contact cleaner would be useful for that.
