BIKE LIFT DIY SCREW TYPE LIKE
Slo1
Rocket 3 r
Hi,
PLease see below my progress on making a copy of the big blue bike lift. I am awaiting some laser cut items for the arms..
Cost to date is shown below
State Wide bearings
51204 thrust bearing $20.00 qty 1 Bearing to go under the top of the screw
FTNM20X4 BRONZE NUT $130 qty 1 - Bronze nut that attaches to the lifted section
HEX20X4 NUT $28 qty 1 - Nut to attach allow screw to be turned
TRM20X4 HEX SCREW $180 qty 1- Main screw shaft
30 MM ROUND NYLON $66. To make the rollers the the arm runs up and down on
Steel from Independent Steel Supplies WA
$120.00
WA Bolts
$50 ish dollars
3D printed parts about $3.00 on resin
HD plasma lazer cutter $200
Total estimated cost $797.
I'll be watching intently. My dad just bought a big blue for his Goldwing, so I can get an up-close look at it when I'm over there, or ask for info. I've been wanting to do this for awhile, but just haven't wanted to pull the trigger on parts. I know the jack screw and bearing/nut for it are, for me at least, going to be the most expensive parts and I just scored several large scissor jacks used for leveling enclosed trailers.
What length is the main screw shaft you're using? Nice welds BTW.
Thanks for the compliment on the welds, The screw started at 1100 mm long but when I spun the nut on it galled and I had to shorten it as I damaged it trying to remove the nut. I will also be nickel plating the nut washer that I have welded to the screw shaft.
