Support on product - great
Fit and Finish - good, some areas are tight and I had to replace both shifter rod and crank pulley oil seals since one was missing the little spring tensioner inside the seal and the other was de-formed with extra plastic in the hole area.
dialing everything in - work in progress, straight forward.
overall - awesome, could use some more R&D to get a 2-3bar map sensor working, I am contemplating using a different ECU all together.
Now that I have done one I can probably do another in about 6-8 hours and I have been approach already by some one to do an install. Just figuring out what my time is worth.
Thanks
HEAD
