Bevel box/drive shaft
oggpog
.040 Over
Rocket3
Heys looking for some tips and advice....
Ive just changed oil and filter on my rocket and now going to do the drive shaft. What's the best oil to put in it and any pitfalls I should be aware of? It's the same old story, once you've done it you know what you're doing but this is a first time for me. Your advice and tips would be much appreciated. Thanks guys!
Mobile 1 75W90 full syn GL5 works for me. Since it is only about 6 oz., I change it every spring. The tricky part is to be very carful when reinstalling the small drain bolt. Torque only to 15 NM. The big fill plug torques to 60 NM but I only tighten mine to 50 NM.
DONT FORGET to lube the driveshaft splines
Thanks for that, I will take care. I've always been extra carful when putting in any plugs just in case I thread them. I bit of time saves a whole lot of pain. Haha
Thanks IMFASTTOO and TO rocket, yeah that's not a bad idea guys. How do you lube the splines? That's definitely going into unknown territory haha
YOU must lube the splines everytime you change the back tire or no longer than 10,000 miles
