Bear claw help.
Radz94
Yardley, PA
2006 Rocket III Standard
How do you remove the bear claw after the two cap screws are out?
See.s to be fastened somewhere in the middle top under tank.
There is a slip on - slip off rubber gromet which slides on to a tab attached to the tank. You will need to pull the bearclaw down after removing the two screws. Reverse the process when re-installing.
Manual is in the little blue link below.
There is a tag under the tank that seats in a bracket with a rubber block at the middle top of the bear claw . so long as the fore and aft bolts are removed the claw should slip down and out !
we must have been replying at the same time lol !
Sorry to trouble you but does it take much force to pull it down?
And once down, is there another screw?
Or just 2 on the sides?
Thanks
