Battery Tender Question
One way to find out. Hook it up and let it sit for 24 hours then give it a shot. If it's only a year old it should start up after the charge. I won't ask how the battery was drained within a year. But, how was the battery drained within a year?
This is a battery polarity protector. Try putting some booster cables on the battery for a few minutes from your car then remove and install the battery tender. As Kevin stated, some of the more sophisticated tenders need to see several volts to ensure the battery is being charged the right way.
I will try that. Thanks!
Try connecting another battery in parallel across the terminals and then charge both of them together, this fools the modern day chargers into thinking it is only one good battery
Write your reply...
