alpental
Turbocharged
I'm installing some Avon Grips, and noticed 2 things. The new grip is about an inch longer than stock, and the spacing between the throttle cable locks is slightly larger. Should I let the extra length of the grip hang off the bar, or should I push it all the way in, thereby moving my mirrors and brake and clutch levers in an inch? Will the different spacing in the throttle cable securing points require cable length adjustment one installed (second picture, Avon on left, stock on right)?
