Oh that SUCKS! About 8 or 9 months ago I looked on EBC website. They had two part numbers listed
for the R3T. Part #MD669XC as the wave rotor and MD669X for regular rotor.
Oh well, I guess I just found something else to design
. Laser cut, precision ground ductile cast iron with
aluminum centers. Kinda sounds like a fun future project. I'm sure there is a retrofit from another model of motorcycle, this bikes not that freaky! All you need is the critical dimensional matches:
1) Center hole diameter
2) Mounting bolt hole diameter
3) Rotor thickness
4) Mounting bolt hole (bolt circle or sometimes referred to as bolt radius)
5) Mounting surface to outside of rotor (offset dimension).
This can't be the only bike with these dimensions. I wouldn't be surprised if there isn't another Triumph
with the same dimensions. If a rotor matches up with the exception that the offset is less, you could easily
shim the rotor to bring it out to match. It would work just fine. But I do like EBC stuff, it just works.
Their website now says TBA....to be announced. Hopefully soon.
