sonny
OK it is my understanding that you need a power commander hooked up if you plan on running the aftermarket cams from the man in the tin shed. This way you can get the **** thing dyno with out any issues. Correct so far or are we all Fuc3ed up? Other question is do you leave the power commander hooked up after the dyno and run as is or download dyno tune to Tune ECU and remove the power commander? Really would like a simple plain English explanation. Getting irritated because am am use to Harley's with a power vision. Much simpler system.
