5.75" Adaptive LED for US$98 each delivered.
Ishrub
2x2010 ABS Roadsters, Sprint ST 1050 ABS, 3x250s
Originally posted here:
Headlight for 2009 Touring
Yea, I bit the bullet and just got some Chinese knockoff Adaptives from Ali Express with free shipping by buying each separately in two transactions, If you order two together you will get a small freight charge.
Choice of black or Chrome face. I went black.
5 3/4' LED Headlamp Driving Light For Harley Motorcycle Projector Headlights 5.75" Adaptive Cornering Led headlight
Price: US $98.41 / piece (Approx. Au$140 each).
Link:
Buy Products Online from China Wholesalers at Aliexpress.com
As always I expect errors in specs listings like wattage which is really made up and far more than their real consumption:
SPECIFICATIONS:
Lumens Output: 3520LM /2120 LM (Hi/Lo)
Color: Black,Chrome
Bulb Socket: H4
Housing: Die-cast Aluminum
Operating Voltage: 9-24V DC
Color Temperature: 6000K Pure White
Housing Material: Die-cast Aluminum
Life Span: 30000+hours
Working temperature: -40~85℃
Package Included:
1PSC 5.75" Round LED Projection Headlight
The use of special sealing treatment technology
With high quality sealant
Don't drop hood,and efficient waterproof
Application:
For Harley with 5.75 In. Round LED Headlight
-'06-'11 VRSCD and VRSCDX
-'15-later XG
-'04-later XL
-'09-'13 XR
-'91-later Dyna(except FLD and '91-'05 FXDWG)
-'84-'99 FLSTS and FXSTS
-'08-'11 FLSTSB
-'05-'06 FLSTSC
-'10-12 FLSTSE
-'00-later FXCW, FXCWC, FXS, FXSB, FXSBSE, FXST, FXSTB, FXSTC and FXSTD Models
For Triumph Motorcycles with 5 3/4 Inch Round LED Headlight
For '05-'10 Speed Triple
For Street Triple (Round Headlight Model)
For Rocket 3/4 and Thunderbird
For Victory Motorbike
For '15-'16 Indian Scout
For '17 Victory Octane
Packaging Details
Unit Type:
piece
Package Weight:
1.5kg
Package Size:
12cm x 10cm x 10cm
Have you actually tried these yet?
i.e. do they not only light the respective array when leaned accordingly, but also actually direct it to the side of the road to illuminate the edge?
They actually show two different lamp types in those images within the same listing
1 has two low beam modules and 4 adaptive modules per array on each side
the other shows 5 low-beam modules and 5 adaptive modules per array
If you compare the listed specs (for whatever they're worth :rolleyes: ) the light output (listed) is higher in this one - US $99.74 25% OFF|5.75 LED Adaptive Motorcycle DOT E9 Headlight For Harley Davidson Sportster 1200 XL1200L Custom XL1200C 883 XL883 Chrome Black on Aliexpress.com | Alibaba Group
which shows images of the 2 & 4 type arrays
It's hard to know what to buy 'blind' and don't think any of the listed specs are worth a **** - personal review/references probably count for more here
This one shows video that shows the tilt sensors actually controlling the arrays
- But I'm more curious about where it throws that light ........
US $109.19 30% OFF|FADUIES Black 5.75" LED Motorcycle Adaptive Headlight For Harley Sportster 1200 XL1200L Custom XL1200C 883 XL883 883L on Aliexpress.com | Alibaba Group
video:
https://cloud.video.taobao.com/play/u/2941350583/p/1/e/6/t/10301/50139420105.mp4
No they have not arrived yet. Shipped by the seller on 2019.04.23 20:15. Cheap free shipping is slow. ;):D
You can pay for express UPS type service but I'm cheap!
Pretty sure it is these coming - wrong and as corrected by barabagris the larger 5 LED each side is the larger 7" light.
The 5.75" have the 4 LED per side .version
5 Hi-beam modules and 5 adaptive modules per array but only 3 Low beam
The middle 3 of 5 in centre row are Low beam which operate alone if upright or with either side adaptives if banked turning a corner. The outer 2 in centre row are Hi beam with the 3 circular ones below.
100% with you there.
tbh I have become rather jaded regarding "copies" generally - as most I have seen are only aesthetic copies. The innards can and do vary hugely. Recently did some side by side work with a neighbour - two "identical" lamps for his BMW. Bright? - well they looked it. But we measured the current draw and one set was 60% less current. tbh neither was much use - so he sent them both back. Sadly I did not have a light meter - soon to be rectified.
I'd rather (naturally) spend less and get what I want. But after spending time and money researching, paying and waiting, then testing: sadly I have hit the conclusion that there is too much uncertainty.
And for the life of me I cannot think of a way to empirically bench test "Adaptives". It is not just a tilt sensor - I know because I built my own adaptive setup using a really accurate tilt sensor. You need accelerometers as well. Tilt sensors can (surprisingly) be triggered by things other than tilt.
I do not ride often at night. So when I do, I want it to work. And I mean really work. My eyes are not getting any younger.
The JWS adaptives I have fitted are the Gen1 (low beam tilt only). These outclass the plain old JWS 8630 by a significant margin even without tipping etc. The Daymaker family (made by Speaker) are somewhere in between.
Can they be bettered? - Yes!. But I am sure that to do so - it will be necessary to use proper beam setters to fit/mount correctly. There would be no high/low beam. There would just be light where it needs to be. But as a group - motorcyclists know better than the combined efforts of R&D teams so "We dont need no stinking beam setters".
7" has 5 - the 5.75 has 4 - it's a real estate issue.
The knockoffs are the same, these arrived today in one package via DHL despite ordering and paying separately to get free shipping.
Shipped by the seller on 2019.04.23 20:15. arrived 2019.05.06 10.30.
2 weeks not too bad for free.:D
5-3-4-LED-Headlamp-Driving-Light-For-Harley-Motorcycle-Projector-Headlights-5-75-Adaptive-Cornering.jpg
