Hey guys and gals. I know it's been. A while so don't hate me. I need to replace or rebuild my rebuild my rear mc. Any suggestions on what to get? I bleed the brakes. It works for part of the day then it's gone. As always your help is appreciated.
Sounds like you have a leak in the system. Does your bike have ABS? If so the trouble could be in the ABS module. If don't have ABS, replace all your lies with stainless braided lines and the problem will be gone once bled properly.
My 2008 Touring did the same, bought rear master rebuild kit from Hermys, took master apart found severly degraded fluid, flushed system, replaced components in m/c and bleed system....all good now.
Good hearing from you, BigNorm.
What motorcycle are you speaking of?
I will interject here that, as an owner of two R3Rs, IMHO OEM Rocket ABS sux to start with.
Hope you are well and still inspecting boobies!
