2005 rocket primary TPS replacement
Jascen
Shawnee,Oklahoma
2005 Rocket 3
I just received my new primary TPS I was looking for tips on installing and adjusting with tuneecu. Any advice would be greatly appreciated.
primary tps. the one in the rear of engine and bottom plates.
make sure old and new tps turn the same way.
some say to use thin shims under the tps at the bolts.
follow the book setting
Plus primary tps is mounted on nber 3 throttle body. If thats not the one yoir changing then you'll have probnlrms. Read guide a few times ask questions prior to slamming that puppy in a door
