legsroses
:) Hi, is there for my 2010.. I don't found nothing but only for 2009 or before.. bye bye from Sicily
hi :), I would like mount 02sensor eliminator on my 2010 roadster because it's restricted for extension than torque.. my bike up to third gear gets respectively these ones speed 80-140-170km vs 100-160-190km of 2009 models or previous.. over all torque is limited of 10,7,5% respectively in I,II,III gear.. I drive previous model in 2009 and I perceived a distinctly different feel at low speeds and in terms of acceleration, this last is passed from 2.8second ;) to 3.2 to 3.5second :rolleyes:.. complicit in all this also the brunt of the discharge and, probably, a different distribution between primary and secondary.. bye bye
Not sure of the translator but here you go....
La modifica che desiderate richiede Tuneboy utilizzando sia software o TuneECU ODBII e un connettore del cavo. Potete disabilitare il sensore O2.
Brudda, you needs to go pack to skool to got a gooder educate .yor england vary badder:D
Actually his English is only a bad translation. Unlike most other languages, English has no rules that are strictly adhered to (including the 'exceptions' rule). So using translator software runs into idiosyncratic miscues because its rules of useage don't translate. Spanish (for example) uses a gender context that is totally lost in English. So while it looks goofey, his intent is pretty clear. ;)
