Replacement Clutch/Brake Levers
FitzAnywhere
2013 Rocket 3 Touring
Hey All.... Attached are photos of my stock brake lever for the 2013 R3T ABS. I'm looking for adjustable levers to replace them.
Any insight is appreciated! Thanks!
I do not believe you will find an aftermarket adjustable lever for touring (wrong atomsplitter has found) , if money is not an option and you want an adjustable lever, i believe you will need to replace master cylinder to accomplish what you want.
I do not believe you will find an aftermarket adjustable lever for touring, if money is not an option and you want an adjustable lever, i believe you will need to replace master cylinder to accomplish what you want.
Was there an OEM option?
It states it will fit Touring models from 07 to 14. Is that a typo? It's basically the same lever I found on my Thunderbird Storm and replaced with shorties:
You are exactly right! The thunderbird and rocket touring share the same master cylinder, im sorry, i only saw the new 2500 models listed.
And thanks, i will be getting a set. Again sorry i didnt see other rocket listings. Thanks for sharing them.
No problemo. I've been on a campaign of shorty levers on all my bikes. Right now the only one to have the OEM's is my GT (oddly enough). The ones that were really hard to find were for my Speed Triple RS. Check out the adjuster on the brake:
