Installed the Rocket 3 GT center stand (images included)
509GT
Theoretical Propagandist
2025 Rocket GT
So it only took 5 days for the stand to make it from Italy to my door in Washington State. Very impressed with the packaging and shipping. Everything was well wrapped and protected...so no damage in transit.
First impressions are the powder coating is very good and did not look or feel cheap. Equal in quality to the bikes own black parts.
The mounting plates are 1/4" steel and the center stand is just like every centerstand you have every seen. Welds are on point, nothing look jury rigged or hinky.
Instructions are printed on 8.5 x 11 paper in color with clear easy to read data. It does not require words, as the images and process is so straight forward, having the bike and parts in front of you and the images... it simply works well.
You will need only basic tools, 8mm socket and allen key, 13mm box end wrench, a couple of Phillips head screws drivers (installing the centerstand springs). Also, you will need a motorcycle pad stand to support the bike while you move and reinstall the kickstand. I kept it under the bike the whole time as double support.
Total time to install was about 45 mins as I was taking my time and trying to take photos and notes.
Engineering is spot on, the holes match up perfectly with the bikes mounting points. Nothing was a struggle and nothing was left out of the kit.
I will say the toughest part of the whole installation was putting the double springs on for the center stand. I had not done a pair in a while and forgot about using Phillips screw drivers to pry down and install.
For those asking, the stand sits high enough so that rear wheel is off the ground about 3/4" of an inch and can be rocked back to take the front wheel off the ground. So yes, the center stand will make a great tool for changing your tires out in a stable configuration other than using a jack stand. The rest here will be pictures. I will try to answer questions as they come up.
More images...
Looks good. The main thing is if YOU like it. I'm afraid thought that 3/4" isn't going to give you the clearance to remove either wheel, but hope that I'm wrong.
I love it. So hoew much air gap do you need? The wheel is free floating, you dont need anymore space than that.
Rear definitely needs space to come down and tilt back so you can get it around the exhaust. The front has to drop straight down enough to get below the fender. Of course you can remove the exhaust and the fender, but.....
As I said, hope I'm wrong
If the lift off the ground isn't high enough to roll out the wheels, you can just put a 2x4 under the center stand feet before lifting. It might take 2 guys to rock it back on the center stand with it that high.
Question, I have 23 Rocket 3 GT. I have switched to mid peg configuration and added the shift assist. Will this stop me from being able to install the center stand? I'm thinking it will as I only see that it is for the GT, not the R.
Also in Washington State
At this time the R cannot use this. Roberto is working on a solution to modify manufacturing to accommodate one. The right side with brake reservoir is the issue.
