Andy Brooke
Wild and free (until the wife tells me different)
West Yorkshire UK
2022 R3R with Gt bars
Coming from a 2.3 to the 2.5, I wondered if anyone has figured out how to grease the drive splines inside the final drive? Or is it not something that needs doing on the 2.5s? Do the splines run in oil?
have to grease splines just like the old one
Thanks for the replies....
But how do you grease the splines when as far as I know the unit is sealed?
Has anyone seen a video showing how its done?
Andy- did you click on the link two posts above? Here it is. Hope that helps...
Just done it... luvley jubley.... Cheers Journeyman..
Can I assume that the bevel box runs in oil so those gears need no maintenance?
I just ordered this for the splines, as it was recommended in the thread. Amazon.com and actually these as well. forwarned is forarmed or something ha ha Amazon.com
Rick,
That grease will not work on the splines. You need to.find some high strength moly lube. 60% moly
Honda use to sell it, but not anymore. What you bought is for when you disassemble the motor, and then use the assembly grease when putting the engine back together. Cam shafts, crank bearings ect.
Rick,
It said that this stuff replaced the one recommended in the thread. M77 Replaces Moly 60- Apparently So | Cleaning, Oil, Maint. I guess not....nothings easy....ok, found this stuff TS Moly Spline Lube 2 Oz.
