atomsplitter
- Joined
- Nov 29, 2007
- Messages
- 3,861
- Location
- Keller, TX
- Ride
- 23 Rocket GT, 20 Bobber Blk, 22 Speed Triple RS
Procedure for T-120:
- Turn the Ignition On: Ensure the motorcycle is in neutral, and turn the ignition key to the "ON" position without starting the engine.
- Toggle the Kill Switch: Move the kill switch to the "OFF" position, then back to the "RUN" position.
- Press and Release the Front Brake: Activate the front brake lever and release it.
- Press and Release the Rear Brake: Activate the rear brake pedal and release it.
- Press and Release the Clutch: Pull the clutch lever and release it.
- Twist the Throttle Forward: Rotate the throttle grip fully forward (to the closed position, opposite of acceleration) until it reaches the stop, then release.
- Press the Cruise Control Button Once: Press the cruise control button on the left switchgear once. This should complete the activation sequence.
