2025 rocket 3 steering lock not working
mo8414
.040 Over
2025 Triumph Rocket 3 Storm GT
Anyone have an issue getting the handle bar lock to work. Been trying to use it the last few days and it wont engage. Is there an easy fix for this, I'd rather not having to take it to the dealer.
It could be they way you're trying to engage the steering lock. You can't engage the lock if the power is off, so before you shut down the engine, turn the bars fully to the left then press the steering lock button then shut down.
If this is how you're doing it & it's not engaging then yes there's an issue, but give it a go using the above method.
I did figure out it was the way I was trying to do it. I was shutting the bike off completely forgetting to do the handle bar lock. Then I would just hit the button up once to turn the display on and try hitting the lock button and it wouldn't work.
Now if I just kill the motor leaving the dispkay on, then hit the button it works everytime so appearently you can't do it just by turning the screen back on with the one click up.
Thanks for taking the time to replay I appreciate it.
